ArcGIS.Core.Data.Analyst3D Namespace / TinEdge Class
    TinEdge Class Methods
    For a list of all members of this type, see TinEdge members.
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the corresponding edge of the triangle opposite to this TIN edge. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the edge beginning at the "toNode" of this TIN edge. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the edge terminating at the "fromNode" of this TIN edge. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the next edge in the triangle. The next edge is in the clockwise direction. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the previous edge in the triangle. The previous edge is counter-clockwise to this TIN edge. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodCompares two TinElement for equality. Compares TinElement.ElementType and TinElement.Index. (Inherited from ArcGIS.Core.Data.Analyst3D.TinElement)
    Public MethodOverridden.  Gets if this element is inside the specified extent. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets this TIN edge as a ArcGIS.Core.Geometry.Polyline. The spatial reference of the returned polyline is set to the spatial reference of the TIN. See TinDatasetDefinition.GetSpatialReference. This method must be called on the MCT. Use QueuedTask.Run.
    Top
