ArcGIS.Desktop.Core.Portal Namespace / PortalQueryParameters Class
    PortalQueryParameters Class Properties
    For a list of all members of this type, see PortalQueryParameters members.
    Public Properties
     NameDescription
    Public PropertyGets or sets the search extent for a spatial search. A valid search requires either a bounding box, or a Query, or both.
    Public PropertyGets or sets the maximum number of results to be included in the result set response. The default value is 10 and the maximum allowed value is 100. The start index, along with the limit parameter can be used to paginate the search results. The actual number of returned results may be less than Limit. This happens when the number of results remaining after StartIndex is less than Limit.
    Public Property Gets or sets the organization id to use in the query.
    Public PropertyGets or sets the query string to search against.
    Public Property Gets a formatted query string based on the PortalQueryParameter properties
    Public PropertyGets or sets the field to sort by. (e.g for groups the allowed field names are title, owner, and created).
    Public PropertyGets or sets a value indicating whether order returns in ascending or descending order. Default is ascending.
    Public PropertyGets or sets the index of the first entry in the result set response. The index number is 1-based. The default value of StartIndex is 1 (e.g.,. the first search result). The start index, along with the Limit parameter can be used to paginate the search results.
    Top
