Public NotInheritable Class ReportProjectItem Inherits ArcGIS.Desktop.Internal.Core.ProjectItem Implements ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged
public sealed class ReportProjectItem : ArcGIS.Desktop.Internal.Core.ProjectItem, ArcGIS.Desktop.Core.IMetadata, ArcGIS.Desktop.Core.IProjectItem, System.ComponentModel.INotifyPropertyChanged
Each Report in a project is associated with a ReportProjectItem. This item contains numerous read-only metadata properties about the report. Although a report may exist in the project, it may not be loaded (an open report view). To reference the actual report and ensure it is loaded into memory, you must use the GetReport method.
var reportsInProject = Project.Current.GetItems<ReportProjectItem>();
foreach (var reportItem in reportsInProject)
//Do Something with the report
ReportProjectItem reportProjItem = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(item => item.Name.Equals("Report Name"));
//Note: Needs QueuedTask to run
Report reportInProject = reportProjItem?.GetReport();
//Open a report project item in a new view.
//A report project item may exist but it may not be open in a view.
//Reference a report project item by name
ReportProjectItem reportPrjItem = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(item => item.Name.Equals("MyReport"));
//Get the report associated with the report project item
Report reportToOpen = reportPrjItem.GetReport();
//Create the new pane
IReportPane iNewReportPane = await ProApp.Panes.CreateReportPaneAsync(reportToOpen); //GUI thread
Report reportToActivate = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault().GetReport();
var reportPane = FrameworkApplication.Panes.FindReportPanes(report).Last();
if (reportPane == null)
return;
//Activate the pane
(reportPane as ArcGIS.Desktop.Framework.Contracts.Pane).Activate();
//Get the "ReportView" associated with the Report Pane.
ReportView reportViewFromPane = reportPane.ReportView;
//Note: Call within QueuedTask.Run()
//Reference a ReportProjectItem in a project by name
ReportProjectItem reportItem = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(item => item.Name.Equals(reportName));
if (reportItem != null)
//Delete the report from the project
Project.Current.RemoveItem(reportItem);
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Core.Item
ArcGIS.Desktop.Reports.ReportProjectItem
