ArcGIS.Desktop.Reports Namespace / ReportsModule Class
Properties Methods Events
    ReportsModule Class Members
    The following tables list the members exposed by ReportsModule.
    Public Properties
     NameDescription
    Public Property Gets the name of the Module. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Public Propertystatic (Shared in Visual Basic) Returns a reference to the current report module in the application. There is only one report module.
    Top
    Protected Properties
     NameDescription
    Protected Internal Property Gets the DAML identifier. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Top
    Public Methods
     NameDescription
    Public Method Gets the set of Search Suggestion IDs. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Top
    Protected Methods
     NameDescription
    Protected Internal Method Modules are constantly polled giving them the opportunity to enable the application's Copy button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Modules are constantly polled giving them the opportunity to enable the application's Copy Path button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Modules are constantly polled giving them the opportunity to enable the application's Cut button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Modules are constantly polled giving them the opportunity to enable the application's Delete button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Modules are constantly polled giving them the opportunity to enable the application's Duplicate button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Modules are constantly polled giving them the opportunity to enable the application's Paste button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Modules are constantly polled giving them the opportunity to enable the application's PasteSpecial button. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method When overridden in a derived class, a Module can return that it can't be unloaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Called when the Copy command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Called when the CopyPath command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Called when the Cut command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Called when the Delete command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Called when the Duplicate command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Override this method to allow users to execute DAML commands specified in this module. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected MethodOverridden.  Called by framework to initialize the report module.
    Protected MethodOverloaded.  (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Protected MethodOverridden.  Called by the Framework when a Pane is activated.
    Protected MethodOverridden.  Called by the Framework when a Pane is closed.
    Protected MethodOverridden.  Called by the Framework when one of the Module's Pane is about to close.
    Protected MethodOverridden.  Called by the Framework when a Pane is deactivated.
    Protected MethodOverridden.  Called by the Framework when a new Pane is opened. This occurs after the pane has been fully initialized.
    Protected Internal Method Override this method to read custom settings written to the current project. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Called periodically by the framework once the module has been loaded. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Override this method to write custom settings to the current project when it is saved. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Called when the Paste command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected Internal Method Called when the PasteSpecial command is executed. (Inherited from ArcGIS.Desktop.Framework.Contracts.Module)
    Protected MethodOverridden.  Called by the framework to uninitialize the report module.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase)
    Top
