ArcGIS.Desktop.Mapping Namespace / Map Class / AddBookmark Method / AddBookmark(MapView,String,String) Method
The map view used to create the bookmark.
The name of the new bookmark.
The description of the new bookmark.
    Creates a new bookmark using the current location and time of the map view. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function AddBookmark( _
       ByVal mapView As MapView, _
       ByVal name As String, _
       ByVal description As String _
    ) As Bookmark
    Parameters
    mapView
    name
    description
    Return Value
    The new bookmark added to the map.
    Exceptions
    ExceptionDescription
    The MapView must contain this Map and the name of the Bookmark must be unique for the Map.
    The MapView cannot be null.
    Requirements
