ArcGIS.Desktop.Mapping Namespace / LasStretchRendererDefinition Class / StretchType Property
Example
    StretchType Property (LasStretchRendererDefinition)
    Gets the stretch type. Default value is ArcGIS.Core.CIM.LASStretchType.StandardDeviations.
    Syntax
    Public Property StretchType As LASStretchType
    public LASStretchType StretchType {get; set;}
    Remarks
    Example
    LAS Points Elevation Stretch Renderer
      var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      // accept the defaults for color ramp, etc
      if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
        CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
        if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
          lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
      // OR use a stretch renderer with stretchType standard Deviations
      var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
      elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
      elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
      // Note: Needs QueuedTask to run
        if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
