Public Function GetUtilityNetwork() As UtilityNetwork
public UtilityNetwork GetUtilityNetwork()
Return Value
The utility network associated with the layer.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| ArcGIS.Core.Data.Exceptions.GeodatabaseUtilityNetworkException | Could not open the utility network. |
static UtilityNetwork GetUtilityNetworkFromLayer(Layer unLayer)
UtilityNetwork utilityNetwork = null;
Layer layer = MapView.Active.Map.GetLayersAsFlattenedList().First();
// This routine obtains a utility network from a FeatureLayer, SubtypeGroupLayer, or UtilityNetworkLayer
if (layer is UtilityNetworkLayer)
UtilityNetworkLayer utilityNetworkLayer = layer as UtilityNetworkLayer;
utilityNetwork = utilityNetworkLayer.GetUtilityNetwork();
else if (layer is SubtypeGroupLayer)
CompositeLayer compositeLayer = layer as CompositeLayer;
utilityNetwork = GetUtilityNetworkFromLayer(compositeLayer.Layers.First());
else if (layer is FeatureLayer)
FeatureLayer featureLayer = layer as FeatureLayer;
using (FeatureClass featureClass = featureLayer.GetFeatureClass())
if (featureClass.IsControllerDatasetSupported())
IReadOnlyList<Dataset> controllerDatasets = new List<Dataset>();
controllerDatasets = featureClass.GetControllerDatasets();
foreach (Dataset controllerDataset in controllerDatasets)
if (controllerDataset is UtilityNetwork)
utilityNetwork = controllerDataset as UtilityNetwork;
else
controllerDataset.Dispose();
return utilityNetwork;
