ArcGIS.Desktop.Mapping Namespace / LasUniqueValueRendererDefinition Class / LasUniqueValueRendererDefinition Constructor / LasUniqueValueRendererDefinition Constructor(LasAttributeType,Boolean,CIMSymbolReference,Double,CIMColorRamp)
The attribute to define the unique values.
(Optional) Flag indicating whether or not to modulate using intensity.
(Optional) Symbol template for the classes.
(Optional) The symbol scale factor assigned to the symbols. Valid values are between -4.0 and 4.0.
(Optional) Color ramp to apply to those classes.
Example
    Creates a unique value renderer definition to draw points in a LAS dataset layer.
    Syntax
    Parameters
    attributeType
    modulateUsingItensity
    symbolTemplate
    symbolScaleFactor
    colorRamp
    Remarks
    Only the following values are valid for attributeType - LasAttributeType.Classification, LasAttributeType.ReturnNumber, LasAttributeType.NumberOfReturns, LasAttributeType.PointSourceID or LasAttributeType.UserData.
    The symbol size is calculated as Math.Pow(2, symbolScaleFactor).
    Example
    LAS Points Classification Unique Value Renderer
      var lasPointsClassificationRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.Classification);
      // accept the defaults for color ramp, symbolTemplate, symbol scale factor
      if (lasDatasetLayer == null)
        return;
      // Note: Needs QueuedTask to run
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassificationRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassificationRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    LAS Points Returns Unique Value Renderer
      var lasPointsReturnsRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.ReturnNumber);
      lasPointsReturnsRendererDef.ModulateUsingIntensity = true;
      lasPointsReturnsRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsReturnsRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsReturnsRendererDef);
    Requirements
    ArcGIS Pro version: 3.2 or higher.
