ArcGIS.Desktop.Mapping Namespace / LasUniqueValueRendererDefinition Class
Members Example
    Represents a unique value renderer definition for a LAS dataset layer.
    Object Model
    LasUniqueValueRendererDefinition ClassCIMColorRamp ClassCIMSymbolReference Class
    Syntax
    Public Class LasUniqueValueRendererDefinition
       Inherits TinUniqueValueRendererDefinition
    public class LasUniqueValueRendererDefinition : TinUniqueValueRendererDefinition
    Remarks
    Once you define a renderer, you can call a surface layer's CanCreateRenderer, CreateRenderer, CanSetRenderer and SetRenderer methods to create and assign a renderer to a surface layer.
    Example
    LAS Points Classification Unique Value Renderer
      var lasPointsClassificationRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.Classification);
      // accept the defaults for color ramp, symbolTemplate, symbol scale factor
      if (lasDatasetLayer == null)
        return;
      // Note: Needs QueuedTask to run
        if (lasDatasetLayer.CanCreateRenderer(lasPointsClassificationRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassificationRendererDef);
          if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
            lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
    LAS Points Returns Unique Value Renderer
      var lasPointsReturnsRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.ReturnNumber);
      lasPointsReturnsRendererDef.ModulateUsingIntensity = true;
      lasPointsReturnsRendererDef.SymbolScaleFactor = 1.0;
        if (lasDatasetLayer.CanCreateRenderer(lasPointsReturnsRendererDef))
          CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsReturnsRendererDef);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.LayerDrawingDefinition
          ArcGIS.Desktop.Mapping.TinRendererDefinition
             ArcGIS.Desktop.Mapping.TinUniqueValueRendererDefinition
                ArcGIS.Desktop.Mapping.LasUniqueValueRendererDefinition
    Requirements
    ArcGIS Pro version: 3.2 or higher.
