ArcGIS.Desktop.Mapping Namespace / Map Class / GetZsFromSurface Method
    Overload List
    OverloadDescription
    Obtains a geometry that is similar to the given input geometry, where some or all Z values are populated from the default Ground Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Obtains a geometry that is similar to the given input geometry, where some or all Z values are populated from the specified Elevation Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
