ArcGIS.Desktop.Mapping Namespace / Map Class / GetZsFromSurface Method / GetZsFromSurface(Geometry,ElevationSurfaceLayer,SurfaceZsMissingHandler) Method
The input geometry
Identifies the surface to be used - if specified null, then the default Ground Surface will be used
Provides options to handle missing Zs in the surface
    Obtains a geometry that is similar to the given input geometry, where some or all Z values are populated from the specified Elevation Surface Layer. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    geometry
    The input geometry
    surfaceLayer
    missingHandler
    Return Value
    A result that contains a status, plus an output geometry only if the status is favorable.
    Exceptions
    ExceptionDescription
    The input geometry is null.
    This Map does not have the specified surfaceLayer.
    This Map does not have a default Ground Surface (when surfaceLayer is null)
    This Map does not have a CIM definition.
    This Map does not have any surfaces.
    Remarks
    The missingHandler will be used to determine what to do if the surface has no data at a particular input geometry point. The corresponding output geometry point or vertex Z will be set to the value specified in the provided missingHandler.OutputZ property. The missingHandler.OnlyProcessMissingZs parameter can be used to overwrite all Z values or only those that are designated as missing based on a comparison with the InputZ value.
    Requirements
    ArcGIS Pro version: 3.2 or higher.
