ArcGIS.Desktop.Layouts Namespace / LayoutFactory Class / CreateLayout Method / CreateLayout(CIMPage) Method
CIMPage
Example
    Creates a new layout using a defined CIM page. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateLayout( _
       Optional ByVal page As CIMPage _
    ) As Layout
    public Layout CreateLayout(
       CIMPage page
    Parameters
    page
    CIMPage
    Return Value
    Returns Layout or a null.
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Example
    Create a new, basic layout and open it
      //Create a new, basic layout and open it.
      //Create layout with minimum set of parameters on the worker thread
      //Note: Needs QueuedTask to run
      var myNewLayout = LayoutFactory.Instance.CreateLayout(8.5, 11, LinearUnit.Inches);
      myNewLayout.SetName("New 8.5x11 Layout");
      //Open new layout on the GUI thread
      await ProApp.Panes.CreateLayoutPaneAsync(myNewLayout);
    Create a new layout using a modified CIM and open it
      //Create a new layout using a modified CIM and open it.
      //The CIM exposes additional members that may not be
      //available through the managed API.
      //In this example, optional guides are added.
      //Create a new CIMLayout on the worker thread
      //Set up a CIM page
      CIMPage newPage = new CIMPage
        //required parameters
        Width = 8.5,
        Height = 11,
        Units = LinearUnit.Inches,
        //optional rulers
        ShowRulers = true,
        SmallestRulerDivision = 0.5,
        //optional guides
        ShowGuides = true
      CIMGuide guide1 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Vertical
      CIMGuide guide2 = new CIMGuide
        Position = 6.5,
      CIMGuide guide3 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Horizontal
      CIMGuide guide4 = new CIMGuide
        Position = 10,
      List<CIMGuide> guideList = new List<CIMGuide>
        guide1,
        guide2,
        guide3,
        guide4
      newPage.Guides = guideList.ToArray();
      //Construct the new layout using the customized cim definitions
      var layout_local = LayoutFactory.Instance.CreateLayout(newPage);
      layout_local.SetName("New 8.5x11 Layout");
      await ProApp.Panes.CreateLayoutPaneAsync(layout_local);
    Change the layout page size
      //Change the layout page size.
      //Reference the layout project item
      LayoutProjectItem lytItem = Project.Current.GetItems<LayoutProjectItem>()
                             .FirstOrDefault(item => item.Name.Equals("MyLayoutItem"));
      if (layoutItem != null)
        //Get the layout
        Layout lyt = lytItem.GetLayout();
        if (lyt != null)
          //Change properties
          CIMPage page = lyt.GetPage();
          page.Width = 8.5;
          page.Height = 11;
          //Apply the changes to the layout
          lyt.SetPage(page);
    Requirements
