ArcGIS.Core.CIM Namespace / CIMGeoFeatureLayerBase Class / PreviousObservationsCount Property
Example
    PreviousObservationsCount Property (CIMGeoFeatureLayerBase)
    Gets or sets the previous observation count.
    Syntax
    public int PreviousObservationsCount {get; set;}
    Public Property PreviousObservationsCount As Integer
    Example
    Set Stream Layer properties via the CIM
      //The layer must be track aware and spatial
      if (streamLayer.TrackType != TrackType.Spatial)
        // not track aware and spatial
      await QueuedTask.Run(() =>
        //get the CIM Definition
        var def = streamLayer.GetDefinition() as CIMFeatureLayer;
        //set the number of previous observations,
        def.PreviousObservationsCount = (int)streamLayer.GetExpirationMaxCount() - 1;
        //set show previous observations and track lines to true
        def.ShowPreviousObservations = true;
        def.ShowTracks = true;
        //commit the changes
        streamLayer.SetDefinition(def);
    Requirements
