ArcGIS.Core.CIM Namespace / CIMGroundToGridCorrection Class
Properties Methods Events
    CIMGroundToGridCorrection Class Members
    The following tables list the members exposed by CIMGroundToGridCorrection.
    Public Constructors
    Public Properties
     NameDescription
    Public PropertyGets or sets the constant scale factor used in ground to grid calculations, only when ScaleType equals GroundToGridScaleType.ConstantFactor.
    Public Property Gets or sets the direction angle (in degrees) that will be used in ground to grid calculations.
    Public Property Gets or sets a value indicating whether ground to grid corrections are currently in operation for the map.
    Public Property Gets or sets the type of scale that will be used in ground to grid calculations.
    Public Property Gets or sets a value indicating whether the direction angle will be used in the ground to grid correction.
    Public Property Gets or sets a value indicating whether the distance scale will be used in the ground to grid correction.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMGroundToGridCorrection.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMGroundToGridCorrection with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMGroundToGridCorrection and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Extension Methods
     NameDescription
    Public Extension MethodCreates a copy of a ArcGIS.Core.CIM.CIMGroundToGridCorrection instance
    Public Extension Method Gets the constant scale factor to be used in ground to grid calculations.
    Public Extension Method Gets the angle in decimal degrees to be used in ground to grid calculations.
    Public Extension Method Gets whether the ground to grid correction is turned on or off.
    Public Extension MethodOverloaded.
    Public Extension Method Gets whether a constant scale factor will be used in the ground to grid correction.
    Public Extension Method Gets whether the direction offset will be used in the ground to grid correction.
    Public Extension Method Gets whether a distance factor will be used in the ground to grid correction.
    Public Extension Method Gets whether a combined scale factor will be used in the ground to grid correction.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
