ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetwork Class / GetAssociationFeatures Method / GetAssociationFeatures(Envelope) Method
Specifies an ArcGIS.Core.Geometry.Envelope that defines the extent for which to return association information.
    Returns a list of AssociationFeatures that represent the associations that exist between features within the given extent. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function GetAssociationFeatures( _
       ByVal extent As Envelope _
    ) As IReadOnlyList(Of AssociationFeature)
    public IReadOnlyList<AssociationFeature> GetAssociationFeatures(
       Envelope extent
    Parameters
    extent
    Return Value
    A list of AssociationFeature objects.
    Exceptions
    ExceptionDescription
    extent is null.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    Only associations where both features are within the provided extent are returned. All supported association types are returned. This routine does not support containment associations with the current release.
    Requirements
