ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraph Class / GetDataModel Method
Example
    GetDataModel Method
    Gets the KnowledgeGraphDataModel for the knowledge graph. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDataModel() As KnowledgeGraphDataModel
    public KnowledgeGraphDataModel GetDataModel()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Retrieving the Data Model
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            //TODO use KG data model...
    Get Data Model Properties
        var kg_props =
            var kg_name = System.IO.Path.GetFileName(
                     System.IO.Path.GetDirectoryName(kg_props.PathOrURL.ToString()));
            System.Diagnostics.Debug.WriteLine(
              $"\r\n'{kg_name}' Datamodel:\r\n-----------------");
            var time_stamp = kg_dm.GetTimestamp();
            var sr = kg_dm.GetSpatialReference();
            System.Diagnostics.Debug.WriteLine($"Timestamp: {time_stamp}");
            System.Diagnostics.Debug.WriteLine($"Sref: {sr.Wkid}");
              $"IsStrict: {kg_dm.GetIsStrict()}");
              $"OIDPropertyName: {kg_dm.GetOIDPropertyName()}");
              $"IsArcGISManaged: {kg_dm.GetIsArcGISManaged()}");
    Requirements
    ArcGIS Pro version: 3.2 or higher.
