Public Function SubmitQuery( _ ByVal queryFilter As KnowledgeGraphQueryFilter _ ) As KnowledgeGraphCursor
public KnowledgeGraphCursor SubmitQuery( KnowledgeGraphQueryFilter queryFilter )
Parameters
- queryFilter
- The query filter to submit
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(async () =>
//and assuming you have established a connection to a knowledge graph
//Construct an openCypher query - return the first 10 entities (whatever
//they are...)
var query = "MATCH (n) RETURN n LIMIT 10";//default limit is 100 if not specified
//other examples...
//query = "MATCH (a:Person) RETURN [a.name, a.age] ORDER BY a.age DESC LIMIT 50";
//query = "MATCH (b:Person) RETURN { Xperson: { Xname: b.name, Xage: b.age } } ORDER BY b.name DESC";
//query = "MATCH p = (c:Person)-[:HasCar]-() RETURN p ORDER BY c.name DESC";
//Create a query filter
//Note: OutputSpatialReference is currently ignored
var kg_qf = new KnowledgeGraphQueryFilter()
QueryText = query
//Optionally - u can choose to include provenance in the results
//(_if_ the KG has provenance - otherwise the query will fail)
bool includeProvenanceIfPresent = KnowledgeGraphSupportsProvenance(kg);
if (includeProvenanceIfPresent)
//Only include if the KG has provenance
kg_qf.ProvenanceBehavior =
KnowledgeGraphProvenanceBehavior.Include;//default is exclude
//submit the query - returns a KnowledgeGraphCursor
using (var kg_rc = kg.SubmitQuery(kg_qf))
//wait for rows to be returned from the server
//note the "await"...
while (await kg_rc.WaitForRowsAsync())
//Rows have been retrieved - process this "batch"...
while (kg_rc.MoveNext())
//Get the current KnowledgeGraphRow
using (var graph_row = kg_rc.Current)
//Graph row is an array, process all returned values...
var val_count = (int)graph_row.GetCount();
for (int i = 0; i < val_count; i++)
var retval = graph_row[i];
//Process row value (note: recursive)
//See "Process a KnowledgeGraphRow Value" snippet
ProcessKnowledgeGraphRowValue(retval);
}//WaitForRowsAsync
}//SubmitQuery
//On the QueuedTask...
//submit query or search to return a KnowledgeGraphCursor
//using (var kgRowCursor = kg.SubmitQuery(kg_qf)) {
//using (var kgRowCursor = kg.SubmitSearch(kg_sf)) {
//"auto-cancel" after 20 seconds
var cancel = new CancellationTokenSource(new TimeSpan(0, 0, 20));
//catch TaskCanceledException
try
while (await kgRowCursor.WaitForRowsAsync(cancel.Token))
//check for row events
while (kgRowCursor.MoveNext())
using (var graph_row = kgRowCursor.Current)
//Timeout expired
catch (TaskCanceledException tce)
//Handle cancellation as needed
cancel.Dispose();
//Given an open-cypher qry against an entity or relationship type
var qry = @"MATCH (p:PhoneNumber) RETURN p LIMIT 10";
//create a KG query filter
var kg_qry_filter = new KnowledgeGraphQueryFilter()
QueryText = qry
//save a list of the ids
var oids = new List<long>();
using (var kgRowCursor = kg.SubmitQuery(kg_qry_filter))
//wait for rows to be returned asynchronously from the server
while (await kgRowCursor.WaitForRowsAsync())
//get the rows using "standard" move next
//current row is accessible via ".Current" prop of the cursor
using (var graphRow = kgRowCursor.Current)
var cell_phone = graphRow[0] as KnowledgeGraphEntityValue;
//note: some user-managed graphs do not have objectids
oids.Add(cell_phone.GetObjectID());
//create a query filter using the oids
if (oids.Count > 0)
//select them on the layer
var qf = new ArcGIS.Core.Data.QueryFilter()
ObjectIDs = oids //apply the oids to the ObjectIds property
//select the child feature layer or standalone table representing
//the given entity or relate type whose records are to be selected
var phone_number_fl = kgLayer.GetLayersAsFlattenedList()
.OfType<FeatureLayer>().First(l => l.Name == "PhoneNumber");
//perform the selection
phone_number_fl.Select(qf);
