ArcGIS.Core.Data.Knowledge Namespace / KnowledgeGraphDataModel Class / GetIdentifierInfo Method
Example
    Gets an object containing information about unique identifiers in the knowledge graph. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetIdentifierInfo() As KnowledgeGraphIdentifierInfo
    public KnowledgeGraphIdentifierInfo GetIdentifierInfo()
    Return Value
    Exceptions
    ExceptionDescription
    Example
    Get Data Model Identifier Info
      await QueuedTask.Run(() =>
        //Create a connection properties
        var kg_props =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        using (var kg = new KnowledgeGraph(kg_props))
          //Get the KnowledgeGraph Data Model
          using (var kg_dm = kg.GetDataModel())
            var kg_id_info = kg_dm.GetIdentifierInfo();
            var kg_id_gen = kg_id_info.GetIdentifierGeneration();
            if (kg_id_info is KnowledgeGraphNativeIdentifier kg_ni)
              System.Diagnostics.Debug.WriteLine(
                $"IdentifierInfo: KnowledgeGraphNativeIdentifier");
            else if (kg_id_info is KnowledgeGraphUniformIdentifier kg_ui)
                $"IdentifierInfo: KnowledgeGraphUniformIdentifier");
                $"IdentifierName: '{kg_ui.GetIdentifierName()}'");
              $"Identifier MethodHint: {kg_id_gen.GetMethodHint()}");
    Requirements
    ArcGIS Pro version: 3.2 or higher.
