ArcGIS.Desktop.Editing Namespace / EditOperation Class / Split Method / Split(Layer,Int64,Geometry) Method
The layer of the feature to split.
The oid of the feature to split.
The geometry to intersect the source feature.
Example
    Split a feature where the splitGeometry intersects it.
    Syntax
    Public Overloads Sub Split( _
       ByVal layer As Layer, _
       ByVal oid As Long, _
       ByVal splitGeometry As Geometry _
    public void Split(
       Layer layer,
       long oid,
       Geometry splitGeometry
    Parameters
    layer
    oid
    splitGeometry
    Exceptions
    ExceptionDescription
    Layer cannot be null.
    Example
    Edit Operation Cut Features
    // Cuts features in the specified feature layer using the provided cut line and clip polygon.
    await QueuedTask.Run(() =>
        var select = MapView.Active.SelectFeatures(clipPolygon);
        var cutFeatures = new EditOperation() { Name = "Cut Features" };
        cutFeatures.Split(featureLayer, objectId, cutLine);
        //Cut all the selected features in the active view
        //Select using a polygon (for example)
        cutFeatures.Split(select, cutLine);
        //Execute to execute the operation
        //Must be called within QueuedTask.Run
        if (!cutFeatures.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = cutFeatures.Execute();
          //or use async flavor
          //await cutFeatures.ExecuteAsync();
    Order edits sequentially
    // Modifies the "NAME" attribute of a specified feature and then splits the feature using the provided polyline, all within a single sequential edit operation.
    // perform an edit and then a split as one operation.
       var newName = "Modified then Split";
       var queryFilter = new QueryFilter() { WhereClause = "OBJECTID = " + objectId.ToString() };
       // create an edit operation and name.
       var op = new EditOperation
         Name = "modify followed by split",         // set the ExecuteMode
         ExecuteMode = ExecuteModeType.Sequential
       using (var rowCursor = layer.Search(queryFilter))
         while (rowCursor.MoveNext())
           using var feature = rowCursor.Current as ArcGIS.Core.Data.Feature;
           op.Modify(feature, "NAME", newName);
       op.Split(layer, objectId, splitLine);
       if (!op.IsEmpty)
         bool result = op.Execute();
       // else
       //  The operation doesn't make any changes to the database so if executed it will fail
    Edit Operation Split Features
    // Splits the specified feature at the given points.
        //Split features at given points
        //Split features using EditOperation.Split overloads
        var splitFeatures = new EditOperation() { Name = "Split Features" };
        //Split the feature at given points
        splitFeatures.Split(featureLayer, objectId, splitPoints);
        if (!splitFeatures.IsEmpty)
          var result = splitFeatures.Execute();
          //await splitAtPointsFeatures.ExecuteAsync();
    // Splits a feature in the specified feature layer based on a given percentage and object ID.
      var percentage = 25.0;
      // split using percentage
      var splitByPercentage = new SplitByPercentage() { Percentage = percentage, SplitFromStartPoint = true };
      splitFeatures.Split(featureLayer, objectId, splitByPercentage);
    // Splits a feature in the specified feature layer into the specified number of parts.
        var numParts = 3;
        // split using equal parts
        var splitByEqualParts = new SplitByEqualParts() { NumParts = numParts };
        splitFeatures.Split(featureLayer, objectId, splitByEqualParts);
    // Splits a feature in the specified feature layer at a given distance and object ID.
        var distance = 150.0;
        // split using single distance
        var splitByDistance = new SplitByDistance() { Distance = distance, SplitFromStartPoint = false };
        splitFeatures.Split(featureLayer, objectId, splitByDistance);
       var distances = new List<double> { 100.0, 200.0, 50.0 };
       // split using varying distance
       var splitByVaryingDistance = new SplitByVaryingDistance() { Distances = distances, SplitFromStartPoint = true, ProportionRemainder = true };
       splitFeatures.Split(featureLayer, objectId, splitByVaryingDistance);
    Requirements
