ArcGIS.Desktop.Editing Namespace / EditOperation Class / Split Method / Split(Layer,IEnumerable<Int64>,IEnumerable<MapPoint>) Method
The layer of the features to split.
The oids of the features to split.
The list of points used to split each feature.
Example
    Split a number of features at multiple points
    Syntax
    Parameters
    layer
    oids
    splitGeometries
    Exceptions
    ExceptionDescription
    Layer and split geometries cannot be null.
    Only polyline layers can be split.
    Example
    Edit Operation Split Features
    // Splits the specified feature at the given points.
    await QueuedTask.Run(() =>
        //Split features at given points
        //Split features using EditOperation.Split overloads
        var splitFeatures = new EditOperation() { Name = "Split Features" };
        //Split the feature at given points
        splitFeatures.Split(featureLayer, objectId, splitPoints);
        //Execute to execute the operation
        //Must be called within QueuedTask.Run
        if (!splitFeatures.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = splitFeatures.Execute();
          //or use async flavor
          //await splitAtPointsFeatures.ExecuteAsync();
    // Splits a feature in the specified feature layer based on a given percentage and object ID.
      var percentage = 25.0;
      // split using percentage
      var splitByPercentage = new SplitByPercentage() { Percentage = percentage, SplitFromStartPoint = true };
      splitFeatures.Split(featureLayer, objectId, splitByPercentage);
    // Splits a feature in the specified feature layer into the specified number of parts.
        var numParts = 3;
        // split using equal parts
        var splitByEqualParts = new SplitByEqualParts() { NumParts = numParts };
        splitFeatures.Split(featureLayer, objectId, splitByEqualParts);
    // Splits a feature in the specified feature layer at a given distance and object ID.
        var distance = 150.0;
        // split using single distance
        var splitByDistance = new SplitByDistance() { Distance = distance, SplitFromStartPoint = false };
        splitFeatures.Split(featureLayer, objectId, splitByDistance);
       var distances = new List<double> { 100.0, 200.0, 50.0 };
       // split using varying distance
       var splitByVaryingDistance = new SplitByVaryingDistance() { Distances = distances, SplitFromStartPoint = true, ProportionRemainder = true };
       splitFeatures.Split(featureLayer, objectId, splitByVaryingDistance);
    Requirements
