// Splits the specified feature at the given points.
await QueuedTask.Run(() =>
//Split features at given points
//Split features using EditOperation.Split overloads
var splitFeatures = new EditOperation() { Name = "Split Features" };
//Split the feature at given points
splitFeatures.Split(featureLayer, objectId, splitPoints);
//Execute to execute the operation
//Must be called within QueuedTask.Run
if (!splitFeatures.IsEmpty)
//Execute and ExecuteAsync will return true if the operation was successful and false if not
var result = splitFeatures.Execute();
//or use async flavor
//await splitAtPointsFeatures.ExecuteAsync();
// Splits a feature in the specified feature layer based on a given percentage and object ID.
var percentage = 25.0;
// split using percentage
var splitByPercentage = new SplitByPercentage() { Percentage = percentage, SplitFromStartPoint = true };
splitFeatures.Split(featureLayer, objectId, splitByPercentage);
// Splits a feature in the specified feature layer into the specified number of parts.
var numParts = 3;
// split using equal parts
var splitByEqualParts = new SplitByEqualParts() { NumParts = numParts };
splitFeatures.Split(featureLayer, objectId, splitByEqualParts);
// Splits a feature in the specified feature layer at a given distance and object ID.
var distance = 150.0;
// split using single distance
var splitByDistance = new SplitByDistance() { Distance = distance, SplitFromStartPoint = false };
splitFeatures.Split(featureLayer, objectId, splitByDistance);
var distances = new List<double> { 100.0, 200.0, 50.0 };
// split using varying distance
var splitByVaryingDistance = new SplitByVaryingDistance() { Distances = distances, SplitFromStartPoint = true, ProportionRemainder = true };
splitFeatures.Split(featureLayer, objectId, splitByVaryingDistance);
