ArcGIS.Desktop.Mapping Namespace / ColorFactory Class / GenerateColorsFromColorRamp Method
The color ramp to use to generate the colors
The number of colors to generate
Example
    GenerateColorsFromColorRamp Method (ColorFactory)
    Generate a list of [count] colors from the specified color ramp. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GenerateColorsFromColorRamp( _
       ByVal colorRamp As CIMColorRamp, _
       ByVal count As Integer _
    ) As List(Of CIMColor)
    public List<CIMColor> GenerateColorsFromColorRamp(
       CIMColorRamp colorRamp,
       int count
    Parameters
    colorRamp
    count
    Return Value
    Exceptions
    ExceptionDescription
    colorRamp
    count must be greater than zero
    Example
    Create and Set a ClassBreaks Renderer
      // Note: call within QueuedTask.Run()
        var fields = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
                           PointCloudRendererType.ClassBreaksRenderer);
        var classBreakDef = new PointCloudRendererDefinition(
          //ELEVATION or INTENSITY
          Field = fields[0]
        //create the renderer
        var cbr = pointCloudSceneLayer.CreateRenderer(classBreakDef)
                                  as CIMPointCloudClassBreaksRenderer;
        //Set up a color scheme to use
        var style = Project.Current.GetItems<StyleProjectItem>()
                                   .First(s => s.Name == "ArcGIS Colors");
        var rampStyle = style.LookupItem(
          StyleItemType.ColorRamp, "Spectrum By Wavelength-Full Bright_Multi-hue_2")
        as ColorRampStyleItem;
        var colorScheme = rampStyle.ColorRamp;
        //Set up 6 manual class breaks
        var breaks = 6;
        var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
                                                    colorScheme, breaks);
        var classBreaks = new List<CIMColorClassBreak>();
        var min = cbr.Breaks[0].UpperBound;
        var max = cbr.Breaks[cbr.Breaks.Count() - 1].UpperBound;
        var step = (max - min) / (double)breaks;
        //add in the class breaks
        double upper = min;
        for (int b = 1; b <= breaks; b++)
          double lower = upper;
          upper = b == breaks ? max : min + (b * step);
          var cb = new CIMColorClassBreak()
            UpperBound = upper,
            Label = string.Format("{0:#0.0#} - {1:#0.0#}", lower, upper),
            Color = colors[b - 1]
          classBreaks.Add(cb);
        cbr.Breaks = classBreaks.ToArray();
        pointCloudSceneLayer.SetRenderer(cbr);
    How to Change Value and Color on an Isosurface
        var variable = voxelLayer.SelectedVariableProfile;
        //Change the color of the first surface for the given profile
        var surface = variable.GetIsosurfaces().FirstOrDefault();
        if (surface != null)
          if (voxelLayer.Visualization != VoxelVisualization.Surface)
            voxelLayer.SetVisualization(VoxelVisualization.Surface);
          //Change the iso surface voxel value
          surface.Value = surface.Value * 0.9;
          //get a random color
          var count = new Random().Next(0, 100);
            ((CIMVoxelStretchRenderer)variable.Renderer).ColorRamp, count);
          var idx = new Random().Next(0, count - 1);
          surface.Color = colors[idx];
          //set the custom color flag true to lock the color
          //locking the color prevents it from being changed if the
          //renderer color range or color theme is updated
          surface.IsCustomColor = true;
          //update the surface
          variable.UpdateIsosurface(surface);
    Requirements
