ArcGIS.Desktop.Mapping Namespace / Map Class / SetBasemapLayers Method / SetBasemapLayers(Item) Method
The local basemap whose layers will be used as basemap content
    Sets the current basemap layers in the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetBasemapLayers(
       Item baseMapItem
    Public Overloads Sub SetBasemapLayers( _
       ByVal baseMapItem As Item _
    Parameters
    baseMapItem
    Exceptions
    ExceptionDescription
    Remarks
    Use this flavor of SetBasemapLayers with either:
    o A base map PortalItem retrieved from your portal or organization (ArcGIS.Desktop.Core.ArcGISPortalExtensions.GetBasemapsAsync)
    o A local base map MapProjectItem within your project (created either via the UI or via the API MapFactory.CreateLocalBasemap)
    Attempting to use any other kind of item will result in an System.ArgumentException
    Requirements
