ArcGIS.Core.CIM Namespace / CIMChart Class
Properties Methods Events
    CIMChart Class Members
    The following tables list the members exposed by CIMChart.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the properties of chart axis.
    Public Property Gets or sets the type of chart.
    Public Property Gets or sets a value indicating whether the server-side processing is enabled for supported chart types and data sources.
    Public Property Gets or sets the general properties of the chart.
    Public Property Gets or sets the legend properties of the chart.
    Public Property Gets or sets a setting which indicates whether chart handles selection in the input layer by creating series only from the selected data or highlights selected values on the chart made from entire dataset.
    Public Property Gets or sets the client metadata about the chart.
    Public Property Gets or sets the multi series chart properties for supported chart types.
    Public Property Gets or sets the name of the chart.
    Public Property Gets or sets the series properties of the chart.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMChart.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMChart with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMChart and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
