ArcGIS.Core.Data.PluginDatastore Namespace / PluginTableTemplate Class / GetNativeRowCount Method
    Gets the count of how many rows are currently in this plug-in table or feature class.
    Syntax
    public virtual long GetNativeRowCount()
    Public Overridable Function GetNativeRowCount() As Long
    Return Value
    The number of rows in this plug-in table or feature class.
    Exceptions
    ExceptionDescription
    This plug-in implementation does not support a native row count.
    Remarks
    The reason why concrete implementations of this abstraction should overwrite this method and IsNativeRowCountSupported (if the underlying data source supports native row count) is strictly for performance reasons. If IsNativeRowCountSupported returns false and a row count is needed for the plug-in table, the framework will call the Search method on the entire plug-in table and then manually iterate through the cursor to determine the number of rows.
    The framework will not call this method if IsNativeRowCountSupported return false.
    Requirements
