ArcGIS.Desktop.Core Namespace / Project Class / ImportItem Method / ImportItem(IProjectMultiItem) Method
    Imports an item to the current project. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function ImportItem( _
       ByVal item As IProjectMultiItem _
    ) As IEnumerable(Of IProjectItem)
    Parameters
    item
    Return Value
    IEnumerable{IProjectItem}
    Exceptions
    ExceptionDescription
    Remarks
    For example, import an ArcMap document. The imported item is converted to the appropriate ArcGIS Pro item and stored in the project.
    Requirements
