ArcGIS.Desktop.Core Namespace / Project Class / SaveFromUntitled Method
    Creates a new project from an untitled session
    Syntax
    public Task<Project> SaveFromUntitled(
       string savePath,
       string projectName
    Public Function SaveFromUntitled( _
       ByVal savePath As String, _
       ByVal projectName As String _
    ) As Task(Of Project)
    Parameters
    savePath
    projectName
    Return Value
    A Task returning an indication if the operation was successful or not; true if the save operation succeeds
    Exceptions
    ExceptionDescription
    The save location can not be found or accessed
    The save location may be on a full disk
    There was an unspecified write error while saving
    There was an unspecified error while saving
    Remarks
    Saving the project requires write access to the location where the project is stored. If another person is using the same project file at the same time, saving your changes will not succeed.
    Requirements
