ArcGIS.Desktop.Core Namespace / Project Class / SaveMetadataAsUsingCustomXSLT Method
    SaveMetadataAsUsingCustomXSLT Method (Project)
    Save the metadata of the current item using customized XSLT. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SaveMetadataAsUsingCustomXSLT(
       string customXSLTFilePath,
       string outputFilePath
    Public Sub SaveMetadataAsUsingCustomXSLT( _
       ByVal customXSLTFilePath As String, _
       ByVal outputFilePath As String _
    Parameters
    customXSLTFilePath
    outputFilePath
    Exceptions
    ExceptionDescription
    Requirements
