Public Overloads Sub Export( _ ByVal exportFormat As ExportFormat _ )
public void Export( ExportFormat exportFormat )
Parameters
- exportFormat
- ExportFormat
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method must be called within the lambda passed to QueuedTask.Run. |
This overload is intended to export a single page layout to a supported output file format. Even if a map series is present, if this overload is chosen, the current layout page will be exported to file.
Each ExportFormat has its own set of configurable set of parameters such as OutputFileName and Resolution. You must first create the export format and then provide that as the only required input parameter.
//Export a single page layout to PDF.
//Create a PDF format with appropriate settings
//BMP, EMF, EPS, GIF, JPEG, PNG, SVG, TGA, and TFF formats are also available for export
string filePath = @"Path and file name for the output export file";
PDFFormat PDF = new PDFFormat()
OutputFileName = filePath,
Resolution = 300,
DoCompressVectorGraphics = true,
DoEmbedFonts = true,
HasGeoRefInfo = true,
ImageCompression = ImageCompression.Adaptive,
ImageQuality = ImageQuality.Best,
LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
//Check to see if the path is valid and export
if (PDF.ValidateOutputFilePath())
//Note: Must be on QueuedTask.Run
layout.Export(PDF); //Export the layout to PDF on the worker thread
//Export a map series with multiple pages to a single PDF.
//Create PDF format with appropriate settings
PDFFormat MS_PDF = new PDFFormat()
Resolution = 300,
//Set up map series export options
MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
ExportPages = ExportPages.Custom, //Provide a specific list of pages
CustomPages = "1-3, 5", //Only used if ExportPages.Custom is set
ExportFileOptions = ExportFileOptions.ExportAsSinglePDF, //Export all pages to a single, multi-page PDF
ShowSelectedSymbology = false //Do no show selection symbology in the output
//Export on the worker thread
if (MS_PDF.ValidateOutputFilePath())
layout.Export(MS_PDF, MS_ExportOptions); //Export to PDF
//Export each page of a map series to an individual TIFF file.
//Create TIFF format with appropriate settings
TIFFFormat TIFF = new TIFFFormat()
Resolution = 300,
ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
HasGeoTiffTags = true,
HasWorldFile = true,
ImageCompression = TIFFImageCompression.LZW
MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
ExportPages = ExportPages.All, //All pages
ExportFileOptions = ExportFileOptions.ExportMultipleNames, //Export each page to an individual file using page name as a suffix.
ShowSelectedSymbology = true //Include selection symbology in the output
//Note: Must be on the QueuedTask.Run()
if (TIFF.ValidateOutputFilePath())
layout.Export(TIFF, MSExportOptions_TIFF); //Export to TIFF
//Export a map frame to JPG.
//Create JPEG format with appropriate settings
//BMP, EMF, EPS, GIF, PDF, PNG, SVG, TGA, and TFF formats are also available for export
JPEGFormat JPG = new JPEGFormat()
Resolution = 300,
ColorMode = JPEGColorMode.TwentyFourBitTrueColor,
Height = 800,
Width = 1200
//Reference the map frame
MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
//Note: Must be on QueuesTask.Run
if (JPG.ValidateOutputFilePath())
mf.Export(JPG); //Export the map frame to JPG
//Export the map view associated with a map frame to BMP.
//Create BMP format with appropriate settings
//EMF, EPS, GIF, JPEG, PDF, PNG, SVG, TGA, and TFF formats are also available for export
BMPFormat BMP = new BMPFormat()
Resolution = 300,
Height = 500,
Width = 800,
await QueuedTask.Run(() =>
MapView mv_bmp = mapFrame.GetMapView(layoutView);
if (mv_bmp != null)
if (BMP.ValidateOutputFilePath())
mv_bmp.Export(BMP); //Export to BMP
