ArcGIS.Desktop.Core Namespace / EditingFrameworkExtender Class / OpenExternalTablePane Method / OpenExternalTablePane(PaneCollection,Item,TableViewMode) Method
The item for which the table pane will be opened
Show all records or just selected
    Open an external table pane for an item. If a table pane is already open it will be activated. You must be on the UI thread to call this function.
    Syntax
    Public Overloads Shared Function OpenExternalTablePane( _
       ByVal paneCollection As PaneCollection, _
       ByVal item As Item, _
       Optional ByVal viewMode As TableViewMode _
    ) As IExternalTablePane
    Parameters
    paneCollection
    item
    viewMode
    Return Value
    Exceptions
    ExceptionDescription
    Table panes cannot be accessed from a thread other than the thread they were created on.
    The map viewer is not initialized.
    Remarks
    There must be an active map view otherwise a System.InvalidOperationException is thrown
    Requirements
    ArcGIS Pro version: 3.3 or higher.
