ArcGIS.Desktop.Reports Namespace / ReportElementFactory Class / CreateMapFrame Method
IElementContainer
Envelope
    CreateMapFrame Method (ReportElementFactory)
    Creates a mapFrame element on a report from an envelope geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CreateMapFrame( _
       ByVal elementContainer As IElementContainer, _
       ByVal envelope As Envelope, _
       ByVal map As Map, _
       ByVal mapFrameName As String _
    ) As MapFrame
    Parameters
    elementContainer
    IElementContainer
    envelope
    Envelope
    map
    mapFrameName
    Exceptions
    ExceptionDescription
    Invalid report section.
    Invalid report.
    Element extents outside section.
    Cannot add map frame to this section type.
    Failed to create map frame.
    Requirements
    ArcGIS Pro version: 3.3 or higher.
