ArcGIS.Desktop.Mapping Namespace / ViewDome Class
Properties Methods
    ViewDome Class Members
    The following tables list the members exposed by ViewDome.
    Public Constructors
     NameDescription
    Public ConstructorOverloaded.
    Top
    Public Properties
     NameDescription
    Public PropertyIdentifier for the exploratory analysis object within its current MapView.
    The ID is only unique to the map view that it was added to. For this reason, the same instance should not be added to more than one MapView. Use the subclass's copy constructor for that.
    (Inherited from ArcGIS.Desktop.Mapping.ExploratoryAnalysis)
    Public Property The current MapView that this exploratory analysis object is in. (Inherited from ArcGIS.Desktop.Mapping.ExploratoryAnalysis)
    Public PropertyGets or sets the ViewDome's maximum distance.
    Defines a far distance limit and size of the view dome in meters. Any scene content far than this value is disregarded.
    Public PropertyGets or sets the ViewDome's minimum distance.
    Defines a near distance limit in meters. Any scene content closer than this value is disregarded.
    Top
    Public Methods
     NameDescription
    Public Methodstatic (Shared in Visual Basic) Get the color used to paint the obstructed parts of ViewDome analysis. This affects all ViewDome objects in the active MapView.
    Public Method Get the ViewDome's Observer to query its position.
    Public Methodstatic (Shared in Visual Basic) Get the color used to paint the visible parts of ViewDome analysis. This affects all ViewDome objects in the active MapView.
    Public Methodstatic (Shared in Visual Basic) Get the color used to paint the sphere wireframe for ViewDomes. This affects all ViewDome objects in the active MapView.
    Public Methodstatic (Shared in Visual Basic) Change the color used to paint the obstructed parts of ViewDome analysis. This affects all ViewDome objects in the active MapView.
    Public MethodSet the ViewDome's Observer to update its position. Must be in the target map's ArcGIS.Core.Geometry.SpatialReference.
    Public Methodstatic (Shared in Visual Basic) Change the color used to paint the visible parts of ViewDome analysis. This affects all ViewDome objects in the active MapView.
    Public Methodstatic (Shared in Visual Basic) Change the color used to paint the sphere wireframe for ViewDomes. This affects all ViewDome objects in the active MapView.
    Top
