ArcGIS.Desktop.Core Namespace / Project Class / ExportMetadata Method / ExportMetadata(String,MDImportExportOption,MDExportRemovalOption,String) Method
Example
    Export metadata. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    outputFilePath
    exportType
    removalOption
    styleSheetPath
    Exceptions
    ExceptionDescription
    Example
    Item: export the metadata of the currently selected item: ExportMetadata
      // Note: Needs QueuedTask to run
      metadataItemExport.ExportMetadata(@"E:\Temp\OutputXML.xml", MDImportExportOption.esriCustomizedStyleSheet, MDExportRemovalOption.esriExportExactCopy, @"E:\StyleSheets\Export\MyExportStyleSheet.xslt");
      // Or export using the current metadata style
      metadataItemExport.ExportMetadata(@"E:\Temp\OutputXML.xml", MDImportExportOption.esriCurrentMetadataStyle, MDExportRemovalOption.esriExportExactCopy);
    Requirements
