ArcGIS.Core.CIM Namespace / CIMBAColorCodedLayerParameters Class
Properties Methods Events
    CIMBAColorCodedLayerParameters Class Members
    The following tables list the members exposed by CIMBAColorCodedLayerParameters.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the level of details. It's a layer ID of a standard geography. If ActiveLevelOfDetail is empty, automatic level selection based on the current map scale will be used.
    Public Property Gets or sets the group of levels.
    Public Property Gets or sets the area of interest parameters.
    Public Property Gets or sets the Color Coded Layer boundary mode.
    Public Property Gets or sets the data source used in calculation of distances. Structure of the value is TYPE;COUNTRY_INFO;LOCAL_DATA_INFO where TYPE can be ONLINE, LOCAL, or CUSTOM. COUNTRY_INFO is country_id{|hierarchy}. For example, US|census or US. LOCAL_DATA_INFO is ID of local dataset. For example, USA_ESRI_2019. For example, for local US 2019 dataset it will be: "LOCAL;;USA_ESRI_2019". If online US data source is used, it may be "ONLINE;US|census;". Can be value of baDataSource GP GPEnvironment variable. https://pro.arcgis.com/en/pro-app/tool-reference/environment-settings/ba-data-source.htm.
    Public Property Gets or sets the level of detail items.
    Public Property Gets or sets the Color Coded Map renderer properties.
    Public Property Gets or sets the results pane settings.
    Public Property Gets or sets the secondary demographic variable name.
    Public Property Gets or sets the demographic variable name.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMBAColorCodedLayerParameters.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMBAColorCodedLayerParameters with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMBAColorCodedLayerParameters and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
