Public Property EntityUsage As FilteredFindPathsEntityUsage
public FilteredFindPathsEntityUsage EntityUsage {get; set;}
//using ArcGIS.Core.Data.Knowledge.Extensions;
await QueuedTask.Run(() =>
var ffp_config = new CIMFilteredFindPathsConfiguration();
ffp_config.Name = "Run FFP Using Defaults";
//Origin Entities
var originEntities = new List<CIMFilteredFindPathsEntity>();
var poi_entity = new CIMFilteredFindPathsEntity();
poi_entity.EntityTypeName = "POI";//All entities of entity type "POI"
poi_entity.PropertyFilterPredicate = "";
originEntities.Add(poi_entity);
//Add the CIMFilteredFindPathsEntity to the OriginEntities collection
ffp_config.OriginEntities = originEntities.ToArray();
//Destination Entities
var destEntities = new List<CIMFilteredFindPathsEntity>();
var supp_entity = new CIMFilteredFindPathsEntity();
supp_entity.EntityTypeName = "Supplier";//All entities of entity type "Supplier"
supp_entity.PropertyFilterPredicate = "";
destEntities.Add(supp_entity);
//Add the CIMFilteredFindPathsEntity to the DestinationEntities collection
ffp_config.DestinationEntities = destEntities.ToArray();
//Path Filters
ffp_config.PathFilters = [];//Empty
//Traversal
ffp_config.TraversalDirections = [];//Empty
//Other
ffp_config.RelationshipCostProperty = "";
ffp_config.DefaultRelationshipCost = 1.0;
ffp_config.DefaultTraversalDirectionType = KGTraversalDirectionType.Any;
ffp_config.EntityUsage = FilteredFindPathsEntityUsage.AnyOriginAnyDestination;
ffp_config.PathMode = KGPathMode.Shortest;
ffp_config.MinPathLength = (int)1;//Min number of relationships in path
ffp_config.MaxPathLength = (int)8;//Max number of relationships in path
ffp_config.MaxCountPaths = (int)100000;//Total number of paths to return
ffp_config.ClosedPathPolicy = KGClosedPathPolicy.Forbid;
ffp_config.TimeFilter = null;
var results = kg.RunFilteredFindPaths(ffp_config);
//TODO process/analyze results
