ArcGIS.Core.CIM Namespace / CIMFilteredFindPathsConfiguration Class / OriginEntities Property
Example
    Gets or sets the origin entities.
    Syntax
    Public Property OriginEntities As CIMFilteredFindPathsEntity()
    public CIMFilteredFindPathsEntity[] OriginEntities {get; set;}
    Example
    Run FFP Using Defaults
      //using ArcGIS.Core.Data.Knowledge.Extensions;
      await QueuedTask.Run(() =>
        var ffp_config = new CIMFilteredFindPathsConfiguration();
        ffp_config.Name = "Run FFP Using Defaults";
        //Origin Entities
        var originEntities = new List<CIMFilteredFindPathsEntity>();
        var poi_entity = new CIMFilteredFindPathsEntity();
        poi_entity.EntityTypeName = "POI";//All entities of entity type "POI"
        poi_entity.PropertyFilterPredicate = "";
        originEntities.Add(poi_entity);
        //Add the CIMFilteredFindPathsEntity to the OriginEntities collection
        ffp_config.OriginEntities = originEntities.ToArray();
        //Destination Entities
        var destEntities = new List<CIMFilteredFindPathsEntity>();
        var supp_entity = new CIMFilteredFindPathsEntity();
        supp_entity.EntityTypeName = "Supplier";//All entities of entity type "Supplier"
        supp_entity.PropertyFilterPredicate = "";
        destEntities.Add(supp_entity);
        //Add the CIMFilteredFindPathsEntity to the DestinationEntities collection
        ffp_config.DestinationEntities = destEntities.ToArray();
        //Path Filters
        ffp_config.PathFilters = [];//Empty
                                    //Traversal
        ffp_config.TraversalDirections = [];//Empty
        //Other
        ffp_config.RelationshipCostProperty = "";
        ffp_config.DefaultRelationshipCost = 1.0;
        ffp_config.DefaultTraversalDirectionType = KGTraversalDirectionType.Any;
        ffp_config.EntityUsage = FilteredFindPathsEntityUsage.AnyOriginAnyDestination;
        ffp_config.PathMode = KGPathMode.Shortest;
        ffp_config.MinPathLength = (int)1;//Min number of relationships in path
        ffp_config.MaxPathLength = (int)8;//Max number of relationships in path
        ffp_config.MaxCountPaths = (int)100000;//Total number of paths to return
        ffp_config.ClosedPathPolicy = KGClosedPathPolicy.Forbid;
        ffp_config.TimeFilter = null;
        var results = kg.RunFilteredFindPaths(ffp_config);
        //TODO process/analyze results
    Requirements
    ArcGIS Pro version: 3.3 or higher.
