ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphDataLoadingEntity Class
Properties Methods Events
    CIMKnowledgeGraphDataLoadingEntity Class Members
    The following tables list the members exposed by CIMKnowledgeGraphDataLoadingEntity.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the type of the entity.
    Public Property Gets or sets the expression which is used to generate the entity type of this entity. This property takes precedence over the TypeIsFieldName and EntityType properties. If the EntityTypeExpression property is not null, the EntityType is generated from the script defined in the expression object. If the EntityTypeExpression property is null, the value of the EntityType property is interpreted based on the TypeIsFieldName property.
    Public Property Gets or sets a value indicating whether this entity should be merged.
    Public Property Gets or sets a value indicating whether this Entity should be found by lookup. This property takes precedence over EntityType and EntityTypeExpression. When defined, the entity will be found by searching the specified types and property values.
    Public Property Gets or sets the name of the entity.
    Public Property Gets or sets the properties of this entity.
    Public Property Gets or sets a value indicating whether the Type property is a name itself or the name of a field.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKnowledgeGraphDataLoadingEntity.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKnowledgeGraphDataLoadingEntity with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKnowledgeGraphDataLoadingEntity and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
