ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphDataLoadingRelationship Class
Properties Methods Events
    CIMKnowledgeGraphDataLoadingRelationship Class Members
    The following tables list the members exposed by CIMKnowledgeGraphDataLoadingRelationship.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether this relationship should be merged.
    Public Property Gets or sets the name of the relationship.
    Public Property Gets or sets the properties of this relationship.
    Public Property Gets or sets the type of the relationship.
    Public Property Gets or sets the expression which is used to generate the relationship type of this relationship. This property takes precedence over the TypeIsFieldName and RelationshipType properties. If the RelationshipTypeExpression is not null, the RelationshipType is generated from the script defined in the expression object. If the RelationshipTypeExpression is null, the value of the RelationshipType property is interpreted based on the TypeIsFieldName property.
    Public Property Gets or sets the source entity name.
    Public Property Gets or sets the target entity name.
    Public Property Gets or sets a value indicating whether the Type property is a name itself or the name of a field.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMKnowledgeGraphDataLoadingRelationship.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMKnowledgeGraphDataLoadingRelationship with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMKnowledgeGraphDataLoadingRelationship and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
