ArcGIS.Core.CIM Namespace / CIMLabelClass Class / MaplexLabelPlacementProperties Property
Example
    Gets or sets the Maplex placement properties which are used when the map uses the Maplex label engine.
    Syntax
    Public Property MaplexLabelPlacementProperties As CIMMaplexLabelPlacementProperties
    public CIMMaplexLabelPlacementProperties MaplexLabelPlacementProperties {get; set;}
    Example
    Modify the Placement/Position of labels - Point geometry
      // Note: call within QueuedTask.Run()
        //Get the layer's definition
        var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //Modify label Placement
        //Check if the label engine is Maplex or standard.
        CIMGeneralPlacementProperties labelEngine =
           MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
        if (labelEngine is CIMStandardGeneralPlacementProperties) //Current labeling engine is Standard labeling engine
          theLabelClass.StandardLabelPlacementProperties.PointPlacementMethod =
                   StandardPointPlacementMethod.OnTopPoint;
        else    //Current labeling engine is Maplex labeling engine
          theLabelClass.MaplexLabelPlacementProperties.PointPlacementMethod =
                  MaplexPointPlacementMethod.CenteredOnPoint;
        lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
        featureLayer.SetDefinition(lyrDefn); //set the layer's definition
    Modify label Rotation - Point geometry
        CIMGeneralPlacementProperties labelEngine = MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
          return;
        //Modify label Rotation
        CIMMaplexRotationProperties rotationProperties = new CIMMaplexRotationProperties
          Enable = true, //Enable rotation
          RotationField = "ELEVATION", //Field that is used to define rotation angle
          AdditionalAngle = 15, //Additional rotation
          RotationType = MaplexLabelRotationType.Arithmetic,
          AlignmentType = MaplexRotationAlignmentType.Perpendicular,
          AlignLabelToAngle = true
        theLabelClass.MaplexLabelPlacementProperties.RotationProperties = rotationProperties;
    Spread labels across Polygon geometry
          return;
        //Spread Labels (words and characters to fill feature)
        // Spread words to fill feature
        theLabelClass.MaplexLabelPlacementProperties.SpreadWords = true;
        //Spread Characters to a fixed limit of 50%
        theLabelClass.MaplexLabelPlacementProperties.SpreadCharacters = true;
        theLabelClass.MaplexLabelPlacementProperties.MaximumCharacterSpacing = 50.0;
    Modify label's Leader Line Anchor point properties - Polygon geometry
          return;
        //If TextSymbol is a call-out the leader line anchor point can be modified
        theLabelClass.MaplexLabelPlacementProperties.PolygonAnchorPointType = MaplexAnchorPointType.Perimeter;
        lyrDefn.LabelClasses = [.. listLabelClasses]; //Set the labelClasses back
    Requirements
