ArcGIS.Core.CIM Namespace / CIMLabelClass Class / StandardLabelPlacementProperties Property
Example
    Gets or sets the standard placement properties which are used when the map uses the standard label engine.
    Syntax
    Public Property StandardLabelPlacementProperties As CIMStandardLabelPlacementProperties
    public CIMStandardLabelPlacementProperties StandardLabelPlacementProperties {get; set;}
    Example
    Modify the Placement/Position of labels - Point geometry
      // Note: call within QueuedTask.Run()
        //Get the layer's definition
        var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //Modify label Placement
        //Check if the label engine is Maplex or standard.
        CIMGeneralPlacementProperties labelEngine =
           MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
        if (labelEngine is CIMStandardGeneralPlacementProperties) //Current labeling engine is Standard labeling engine
          theLabelClass.StandardLabelPlacementProperties.PointPlacementMethod =
                   StandardPointPlacementMethod.OnTopPoint;
        else    //Current labeling engine is Maplex labeling engine
          theLabelClass.MaplexLabelPlacementProperties.PointPlacementMethod =
                  MaplexPointPlacementMethod.CenteredOnPoint;
        lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
        featureLayer.SetDefinition(lyrDefn); //set the layer's definition
    Requirements
