ArcGIS.Core.Data.UtilityNetwork Namespace / UtilityNetwork Class / ValidateNetworkTopology Method / ValidateNetworkTopology(Geometry,ServiceSynchronizationType,ValidationType) Method
The extent of the area to be validating. If this parameter is missing or null, the entire extent of the utility network is used.
Specifies which implementation of the service endpoint to call. This parameter is ignored for non-services based utility networks.
Specifies the type of validation.
    Validates the utility network topology within the provided extent according to the provided validation type. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    extent
    serviceSynchronizationType
    validationType
    Return Value
    A ValidationResult that describes the result of the operation.
    Exceptions
    ExceptionDescription
    This operation cannot be invoked inside ArcGIS.Core.Data.Geodatabase.ApplyEdits or when an edit operation is in progress.
    serviceSynchronizationType and/or validationType are invalid.
    A geodatabase-related exception has occurred.
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    • This routine generates its own editing transaction and therefore cannot be wrapped inside a separate transaction.
    • Note that regardless of the ArcGIS.Core.Data.ServiceSynchronizationType used, this C# routine is still synchronous; the current thread will block until the routine completes.
    Requirements
    ArcGIS Pro version: 3.3 or higher.
