ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / UpdateMsByDistance Method
The input polyline.
The index of the part from which to start.
The index of the point (relative to the part) from which to start.
The index of the part from which to end.
The index of the point (relative to the part) from which to end.
The start M-value.
The end M-value.
The method to use when updating M-values. You can use a combination of update methods by using the bitwise OR operator. For example, to interpolate between the input points and to extrapolate before the input points, useUpdateMMethod.Interpolate | UpdateMMethod.ExtrapolateBefore.
Determines whether distances between parts of the polyline should be ignored or not.
Example
    UpdateMsByDistance Method (IGeometryEngine)
    Updates M-values along the shortest path between the specified vertices. The interpolation ratio is determined by the input M-values and Euclidean distance along that path.
    Syntax
    Parameters
    polyline
    The input polyline.
    fromPartIndex
    fromPointIndex
    toPartIndex
    toPointIndex
    fromM
    The start M-value.
    toM
    The end M-value.
    updateMMethod
    ignoreGaps
    Return Value
    A polyline with updated M-values. If the input polyline is empty, then it is returned unchanged.
    Exceptions
    ExceptionDescription
    The input polyline is null.
    The geometry is not M-Aware.
    The spatial reference is an image coordinate system.
    fromPartIndex or fromPointIndex or toPartIndex or toPointIndex is negative.
    toPartIndex is less than fromPartIndex.
    The extrapolation range is invalid.
    fromPartIndex or toPartIndex is greater than or equal to the number of parts in the multipart.
    fromPointIndex or toPointIndex is greater than or equal to the number of points in the specified part.
    Example
    Update M-values along the shortest path between the specified vertices - UpdateMsByDistance
      string json = "{\"hasM\":true,\"paths\":[[[-8,2,1],[-8,5,8],[-5,5,0],[-5,7,12]]],\"spatialReference\":{\"wkid\":4326}}";
      polyline = PolylineBuilderEx.FromJson(json);
      Polyline outputPolyline = GeometryEngine.Instance.UpdateMsByDistance(polyline, 0, 0, 0, 2, 10, 20, UpdateMMethod.Interpolate, true);
      // The xy-coordinates don't change.
      // The M-values of the vertices in outputPolyline are { 10, 15, 20, 12 }
      json = "{\"hasM\":true,\"paths\":[[[-8,2,1],[-8,5,8],[-5,5,0],[-5,7,12]],[[3,2,20],[7,2,30],[7,4,10],[13,4,5]]]}";
      outputPolyline = GeometryEngine.Instance.UpdateMsByDistance(polyline, 0, 2, 1, 1, 10, 20, UpdateMMethod.ExtrapolateBefore, true);
      // The M-values of the vertices in part 0 of outputPolyline are { -5, 2.5, 10, 5 }
      // The M-values of the vertices in part 1 of outputPolyline are { 20, 20, 10, 5 }
    Requirements
    ArcGIS Pro version: 3.3 or higher.
