CreateLinkChart(String,Uri,KnowledgeGraphLayerIDSet) Method
Creates a link chart map (a map of type MapType.LinkChart) with a specified knowledge graph service.
This method must be called on the MCT. Use QueuedTask.Run.
Parameters
- name
- The name of the map.
- knowledgeGraphServiceUri
- A Uri link to a knowledge graph service.
- idSet
- A set of Named Object types and record ids that sets the content of the Knowledge Graph layer. See KnowledgeGraphLayerIDSet.
Return Value
A
map of type MapType.LinkChart.
Get Selected records and open in a new link chart
// get the active investigation view
var iv = KnowledgeGraphInvestigationView.Active;
await QueuedTask.Run(() =>
// get the investigation
var inv = iv.Investigation;
// get the set of selected records
var idSet = iv.GetSelectedRecords();
// view these records in a link chart
var map = MapFactory.Instance.CreateLinkChart("myLinkChart", new Uri(inv.ServiceUri), idSet);
ProApp.Panes.CreateMapPaneAsync(map);
Create a Link Chart Containing All Records for a KG
//Create the link chart and show it
//build the IDSet using KnowledgeGraphFilterType.AllNamedObjects
var idSet = KnowledgeGraphLayerIDSet.FromKnowledgeGraph(
kg, KnowledgeGraphFilterType.AllNamedObjects);
var linkChart = MapFactory.Instance.CreateLinkChart(
"KG Link Chart", kg, idSet);
FrameworkApplication.Panes.CreateMapPaneAsync(linkChart);
Create a Link Chart With an Empty KG Layer
//Create the link chart with a -null- id set
//This will create a KG Layer with empty sub-layers
//(Note: you cannot create an empty KG layer on a map - only on a link chart)
"KG Link Chart", kg, null);
Create a link chart with all the entities of the Knowledge Graph
using (var kg_for_lc = new KnowledgeGraph(
new KnowledgeGraphConnectionProperties(new Uri(url))))
kg_for_lc, KnowledgeGraphFilterType.AllEntities);
var newLinkChart = MapFactory.Instance.CreateLinkChart(
"All_Entities link chart", kg_for_lc, idSet);
Create a Link Chart from a query
//use the results of a query to create an idset. Create the link chart
//containing just records corresponding to the query results
var qry = @"MATCH (p1:PhoneNumber)-[r1:MADE_CALL|RECEIVED_CALL]->(c1:PhoneCall)<-" +
@"[r2:MADE_CALL|RECEIVED_CALL]-(p2:PhoneNumber)-[r3:MADE_CALL|RECEIVED_CALL]" +
@"->(c2:PhoneCall)<-[r4:MADE_CALL|RECEIVED_CALL]-(p3:PhoneNumber) " +
@"WHERE p1.FULL_NAME = ""Robert Johnson"" AND " +
@"p3.FULL_NAME= ""Dan Brown"" AND " +
@"p1.globalid <> p2.globalid AND " +
@"p2.globalid <> p3.globalid " +
@"RETURN p1, r1, c1, r2, p2, r3, c2, r4, p3";
var dict = new Dictionary<string, List<long>>();
await QueuedTask.Run(async () =>
using (var kg_for_lc = kgLayer.GetDatastore())
var graphQuery = new KnowledgeGraphQueryFilter()
QueryText = qry
using (var kg_rc = kg_for_lc.SubmitQuery(graphQuery))
while (await kg_rc.WaitForRowsAsync())
while (kg_rc.MoveNext())
using (var graphRow = kg_rc.Current)
// process the row
var cnt_val = (int)graphRow.GetCount();
for (int v = 0; v < cnt_val; v++)
var obj_val = graphRow[v] as KnowledgeGraphNamedObjectValue;
var type_name = obj_val.GetTypeName();
var oid = (long)obj_val.GetObjectID();
if (!dict.ContainsKey(type_name))
dict[type_name] = new List<long>();
if (!dict[type_name].Contains(oid))
dict[type_name].Add(oid);
//make an ID Set to create the LinkChart
var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg_for_lc, dict);
"KG With ID Set", kg_for_lc, idSet);
Create Link Chart from FFP Results
//using ArcGIS.Core.Data.Knowledge.Extensions;
var ffp_config = new CIMFilteredFindPathsConfiguration();
ffp_config.Name = "Create Link Chart from FFP Results";
//set up config
var results = kg.RunFilteredFindPaths(ffp_config);
var pathsEntitiesAndRelationships = results.ExtractPathsEntitiesAndRelationships(null);
//Create a KG layer id set
var kgLayerIdSet = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(
pathsEntitiesAndRelationships.ToKnowledgeGraphIDSet(
KGResultContentFromFFP.EntitiesAndRelationships));
//Create a brand new link chart with the results and show it
var linkChart = MapFactory.Instance.CreateLinkChart("KG Intro", kg, kgLayerIdSet);
var mapPane = await FrameworkApplication.Panes.CreateMapPaneAsync(linkChart);
var linkChartView = mapPane.MapView;
//Change layout algo to match the default used by the UI after FFP
await linkChartView.SetLinkChartLayoutAsync(
KnowledgeLinkChartLayoutAlgorithm.Hierarchical_TopToBottom);
//Set root nodes - they correspond to the origin nodes of the result paths
var kgLayerIdSetForRootNodes = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(
KGResultContentFromFFP.OnlyPathsOriginEntities));
//To correctly identify the ids in the link chart we must change the ids
//from Geodatabase oids returned in the KnowledgeGraphLayerIDSet to the
//temporary/synthetic oids used by layers in the link chart...
var kg_layer = linkChart.GetLayersAsFlattenedList().OfType<KnowledgeGraphLayer>().First();
var mapMembers = kg_layer.GetMapMembersAsFlattenedList();
var oidDict = kgLayerIdSetForRootNodes.ToOIDDictionary();
var mmDict = new Dictionary<MapMember, List<long>>();
foreach (var kvp in oidDict)
var named_type = kvp.Key;
foreach (var mm in mapMembers)
if (mm is LinkChartFeatureLayer fl_lc && fl_lc.IsEntity)
if (fl_lc.GetTypeName().ToLower() == named_type.ToLower())
var lc_oids = new List<long>();
//these oids are from the geodatabase
var oid_field = $"{fl_lc.GetTypeName()}.objectid";
var id_list = string.Join(',', kvp.Value.ToArray());
var where = $"{fl_lc.GetTypeName()}.objectid IN ({id_list})";
var qf = new ArcGIS.Core.Data.QueryFilter()
WhereClause = where,
SubFields = $"LC.OID,{oid_field}"//the 'LC.OID' oids are the ones
//we need for the mapmember id set
//in the link chart
var rc = fl_lc.Search(qf);
var oid_idx = rc.FindField(oid_field);
while (rc.MoveNext())
var oid = (long)rc.Current[oid_idx];
var lc_oid = rc.Current.GetObjectID();
lc_oids.Add(lc_oid);
rc.Dispose();
mmDict[fl_lc] = lc_oids;
break;
var mmIdSet = MapMemberIDSet.FromDictionary(mmDict);
linkChartView.SetRootNodes(mmIdSet);
Create a LinkChart from a subset of an existing LinkChart IDSet
//var map = ...
if (map.MapType != MapType.LinkChart)
return;
// find the KG layer
//var kgLayer = map.GetLayersAsFlattenedList()
// .OfType<KnowledgeGraphLayer>().FirstOrDefault();
// find the first LinkChartFeatureLayer in the KG layer
var lcFeatureLayer = kgLayer.GetLayersAsFlattenedList().OfType<LinkChartFeatureLayer>().FirstOrDefault();
if (lcFeatureLayer != null)
return;
// get the ID set of the KG layer
var idSet = kgLayer.GetIDSet();
// get the named object type in the KG that the LinkChartFeatureLayer represents
var typeName = lcFeatureLayer.GetTypeName();
// if there are items in the ID Set for this type
if (idSet.Contains(typeName))
// build a new ID set containing only these records
var dict = idSet.ToOIDDictionary();
var oids = dict[typeName];
var newDict = new Dictionary<string, List<long>>();
newDict.Add(typeName, oids);
var newIDSet = KnowledgeGraphLayerIDSet.FromDictionary(kgLayer.GetDatastore(), newDict);
// now create a new link chart using just this subset of records
MapFactory.Instance.CreateLinkChart("subset LinkChart", kgLayer.GetDatastore(), newIDSet);
ArcGIS Pro version: 3.3 or higher.
