ArcGIS.Desktop.Mapping Namespace / MapFactory Class / CreateLinkChart Method / CreateLinkChart(String,Uri,KnowledgeGraphLayerIDSet,String) Method
The name of the map.
A Uri link to a knowledge graph service.
A set of Named Object types and record ids that sets the content of the Knowledge Graph layer. See KnowledgeGraphLayerIDSet.
The path to a link chart to use as a template for layout and styling. Use null or an empty string to create the link chart with the default layout and styling. If specified, the template link chart must use the same knowledge graph service as knowledgeGraphServiceUri.
Example
    Creates a link chart map (a map of type MapType.LinkChart) with a specified knowledge graph service. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function CreateLinkChart( _
       ByVal name As String, _
       ByVal knowledgeGraphServiceUri As Uri, _
       ByVal idSet As KnowledgeGraphLayerIDSet, _
       ByVal templateLinkChartPath As String _
    ) As Map
    Parameters
    name
    idSet
    Return Value
    A map of type MapType.LinkChart.
    Exceptions
    ExceptionDescription
    knowledgeGraphServiceUri cannot be null.
    templateLinkChartPath either does not exist in the current project, is not a Link Chart, does not contain a Knowledge Graph layer or does not contain the same Knowledge Graph service as knowledgeGraphServiceUri.
    idSet contains invalid Name Object types..
    Remarks
    The KnowledgeGraph layer created in the Link Chart contains sub layers for each Named Object type. To set the output content of the KnowledgeGraph composite layer, add an entry to the idSet for each Named Object type to be included in the output along with a list of their relevant record ids. Specify a null or empty list for a given entry to include all the records for that particular type at the time of creation.
    Note: Named Object names in a ID set entry are case-sensitive.
    If there are Named Object type names specified in the ID set that do not match a Named Object type name in the KnowledgeGraph then a KnowledgeGraphLayerException will be thrown when the layer is created. The exception will contain the list of invalid Named Object types.
    If you specify a null or empty IDSet, then the KnowledgeGraph layer will contain all the sub layers for the Named Object types but the sub layers will contain no content.
    Example
    Create a LinkChart from a subset of an existing LinkChart IDSet
      //var map = ...
      if (map.MapType != MapType.LinkChart)
        return;
      // find the KG layer
      //var kgLayer = map.GetLayersAsFlattenedList()
      //        .OfType<KnowledgeGraphLayer>().FirstOrDefault();
      // find the first LinkChartFeatureLayer in the KG layer
      var lcFeatureLayer = kgLayer.GetLayersAsFlattenedList().OfType<LinkChartFeatureLayer>().FirstOrDefault();
      if (lcFeatureLayer != null)
        return;
      await QueuedTask.Run(() =>
        // get the ID set of the KG layer
        var idSet = kgLayer.GetIDSet();
        // get the named object type in the KG that the LinkChartFeatureLayer represents
        var typeName = lcFeatureLayer.GetTypeName();
        // if there are items in the ID Set for this type
        if (idSet.Contains(typeName))
          // build a new ID set containing only these records
          var dict = idSet.ToOIDDictionary();
          var oids = dict[typeName];
          var newDict = new Dictionary<string, List<long>>();
          newDict.Add(typeName, oids);
          var newIDSet = KnowledgeGraphLayerIDSet.FromDictionary(kgLayer.GetDatastore(), newDict);
          // now create a new link chart using just this subset of records
          MapFactory.Instance.CreateLinkChart("subset LinkChart", kgLayer.GetDatastore(), newIDSet);
    Create a link chart based on a template link chart
      // note that the template link chart MUST use the same KG server
        // find the existing link chart by name
        var projectItem = Project.Current.GetItems<MapProjectItem>()
        .FirstOrDefault(pi => pi.Name == "Acme Link Chart");
        var linkChartMap = projectItem?.GetMap();
        if (linkChartMap == null)
          return;
        //Create a connection properties
        var kg_props2 =
            new KnowledgeGraphConnectionProperties(new Uri(url));
        try
          //Open a connection
          using (var kg_for_lc = new KnowledgeGraph(kg_props2))
            //Add all entities to the link chart
            var idSet = KnowledgeGraphLayerIDSet.FromKnowledgeGraph(
                  kg_for_lc, KnowledgeGraphFilterType.AllEntities);
            //Create the new link chart and show it
            var newLinkChart = MapFactory.Instance.CreateLinkChart(
                              "KG from Template", kg_for_lc, idSet, linkChartMap.URI);
            FrameworkApplication.Panes.CreateMapPaneAsync(newLinkChart);
        catch (Exception ex)
          System.Diagnostics.Debug.WriteLine(ex.ToString());
    Checking KnowledgeGraphLayerException
      // running on QueuedTask
      var dict = new Dictionary<string, List<long>>();
      dict.Add("person", new List<long>());  //Empty list means all records
      dict.Add("made_call", null);  //null list means all records
      // or specific records - however the ids are obtained
      dict.Add("phone_call", new List<long>() { 1, 5, 18, 36, 78 });
      // make the id set
      var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict);
      try
        //Create the link chart and show it
        var linkChart = MapFactory.Instance.CreateLinkChart(
                          "KG With ID Set", kg, idSet);
        FrameworkApplication.Panes.CreateMapPaneAsync(linkChart);
      catch (KnowledgeGraphLayerException e)
        // get the invalid named types
        //   remember that the named types are case-sensitive
        var invalidNamedTypes = e.InvalidNamedTypes;
        // do something with the invalid named types
        // for example - log or return to caller to show message to user
    Requirements
    ArcGIS Pro version: 3.3 or higher.
