ArcGIS.Core.CIM Namespace / CIMPointCloudLayer Class / PointsBudget Property
Example
    Gets or sets the double value to determine the upper limit on the number of points drawn.
    Syntax
    public int PointsBudget {get; set;}
    Public Property PointsBudget As Integer
    Example
    Edit Density settings
      await QueuedTask.Run(() =>
        var def = pointCloudSceneLayer.GetDefinition() as CIMPointCloudLayer;
        //PointsBudget - corresponds to Display Limit on the UI
        // - the absolute maximum # of points to display
        def.PointsBudget = 1000000;
        //PointsPerInch - corresponds to Density Min --- Max on the UI
        // - the max number of points per display inch to renderer
        def.PointsPerInch = 15;
        //Commit changes back to the CIM
        pointCloudSceneLayer.SetDefinition(def);
    Requirements
