ArcGIS.Core.CIM Namespace / CIMPointCloudRenderer Class
Properties Methods Events
    CIMPointCloudRenderer Class Members
    The following tables list the members exposed by CIMPointCloudRenderer.
    Public Properties
     NameDescription
    Public Property Gets or sets the filter used to filter the points being drawn.
    Public Property Gets or sets the field used to render the points.
    Public Property Gets or sets the field transform type.
    Public Property Gets or sets the symbol type.
    Public Property Gets or sets the algorithm used to determine the symbol size.
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
