ArcGIS.Core.CIM Namespace / CIMPointCloudRGBRenderer Class
Properties Methods Events
    CIMPointCloudRGBRenderer Class Members
    The following tables list the members exposed by CIMPointCloudRGBRenderer.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the filter used to filter the points being drawn. (Inherited from ArcGIS.Core.CIM.CIMPointCloudRenderer)
    Public Property Gets or sets the field used to render the points. (Inherited from ArcGIS.Core.CIM.CIMPointCloudRenderer)
    Public Property Gets or sets the field transform type. (Inherited from ArcGIS.Core.CIM.CIMPointCloudRenderer)
    Public Property Gets or sets the symbol type. (Inherited from ArcGIS.Core.CIM.CIMPointCloudRenderer)
    Public Property Gets or sets the algorithm used to determine the symbol size. (Inherited from ArcGIS.Core.CIM.CIMPointCloudRenderer)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMPointCloudRGBRenderer.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMPointCloudRGBRenderer with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMPointCloudRGBRenderer and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
