Public Overrides Function ToJson( _ Optional ByVal settings As JsonSerializationSettings _ ) As String
public override string ToJson( JsonSerializationSettings settings )
Parameters
- settings
- The JSON serialization settings.
// Note: must be called on the QueuedTask
//On the QueuedTask
//Place a polygon symbol using the mapview extent geometry
var extent = MapView.Active.Extent;
//Contract the extent
var polygonEnv = extent.Expand(-100000, -90000, false);
//create a polygon using the envelope
var polygon = PolygonBuilderEx.CreatePolygon(polygonEnv);
//specify a symbol
var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.GreenRGB);
//create a CIMGraphic
var graphic = new CIMPolygonGraphic()
Symbol = poly_symbol.MakeSymbolReference(),
Polygon = polygon,
graphicsLayer.AddElement(graphic);
