| Name | Description | |
![]() | CIMPresentationTransition Constructor |
The following tables list the members exposed by CIMPresentationTransition.
![]() | Duration | Gets or sets the transition duration in seconds. |
![]() | FlyTransitionMode | Gets or sets the fly transition mode: Hop, Linear, etc. |
![]() | SwipeDirection | Gets or sets the swipe transition direction. |
![]() | TransitionType | Gets or sets the transition type. |
![]() | Clone | Creates a deep copy of CIMPresentationTransition. |
![]() ![]() | FromJson | Reconstructs the CIMPresentationTransition with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMPresentationTransition and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
