ArcGIS.Core.Data.Realtime Namespace / RealtimeFeatureClass Class / GetExpirationMaxAge Method
    GetExpirationMaxAge Method (RealtimeFeatureClass)
    Gets the expiration maximum age for features. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetExpirationMaxAge() As TimeSpan
    public TimeSpan GetExpirationMaxAge()
    Return Value
    The System.TimeSpan indicating features older than this value are being removed.
    Exceptions
    ExceptionDescription
    Remarks
    When RealtimeFeatureClassDefinition.HasTrackIDField is true, it represents maximum age within each track. Previous observations that are older than the maximum expiration age comparing to the latest observation in the same track, get removed.
    When RealtimeFeatureClassDefinition.HasTrackIDField is false, features older than the maximum expiration age, comparing to the current time, get removed.
    Requirements
